Never seen a deadbolt screw with this pattern (pic)...
Received 0 Votes
What do I use to remove them? Nothing I have is turning them.
Those are tamper resistant screws. A flat blade screwdriver can grip to tighten but slips off in the other direction so you cannot remove the fastener. If I have to remove them I drill out the screw. You can also grind the head off with a Dremel tool. And if you're feeling lucky you can use a center punch or tiny chisel and work on the perimeter to unscrew it.
I use a modified flat blade screwdriver for this purpose; with the tip filed to resemble a "V" shape, and with the edges filed sharp, in the way of opposing "chisel" points.
You can also use a spanner, or "snake eyes" screwdriver, with the spanner points ground similarly.
If you have the funds, you can purchase a screwdriver for the purpose......it has 2 hardened "back angle" chisel points.....I think it was called "The Unscrew It"
Having said all the above, and never seeming to have one of the above at hand when I need it, a standard "new" (sharp) flat blade usually works, if you press hard while turning only a few degrees until you encounter the "ramp" , then repeating several times, and in this way, you dig a ledge into what is usually the soft aluminum or brass screw head, finally allowing you to get a purchase on it.
Last resort - 'tin' the tip of the screwdriver with a tiny amount of solder, heat the screws with a propane torch.
Doesn't have to be a good solder joint, just enough to keep the blade from skidding out.
