Moving lock face plate
Old 02-27-24, 08:25 PM
P
Received 1 Upvote on 1 Post
Each time I lock the entrance door, I have to pull the door hard. Ideally the lock face plate needs to be moved by about 1/8". How can I fill the old bolt holes before drilling new holes? Thank you.
Old 02-27-24, 08:34 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
If you are talking about moving the strike plate, which is the part mounted on the door jamb, go buy a 1/4" wood dowel and some wood glue. Remove the strike plate and drill out the old holes with a 1/4" drill bit. Then glue in short pieces of dowel and tap them in with a hammer until they are flush.
Wait about 2 hours to give the glue time to cure before reinstalling your strike plate. Drill new pilot holes for your strike plate screws, and install.
Old 02-27-24, 10:29 PM
P
Thank you, xsleeper, for the solution.
Old 02-28-24, 08:09 AM
R
Received 45 Upvotes on 42 Posts
Alternatively, if you only need 1/16 to 1/8", and it's a residential brass strike plate, use a good flat file, with the plate in a bench vise or vice grips, will do the trick also.
pjaffe voted this post useful.
Old 04-11-24, 08:53 AM
P
Thank you, Xsleeper. It worked beautifully.
