Stiff Lock
Stiff Lock
Last summer I replaced the lock in the main front door. It's been fine until the weather got colder. Now it is stiff to turn the key in the lock - and getting stiffer!
What can I do to make it easier to turn? I think I almost broke my finger last time trying to turn it.
stiff lock
Good evening. First; is the lock stiff to operate when the door is open? If it is you can lubricate it with WD40 in the keyhole and sliding the key in and out to distribute the liquid. If it is stiff only when the door is closed you may have to file the striker plate opening a little larger whereever it is rubbing on the latch/bolt.
Let us know how you make out and have a good day.
