Changing locks when moving in a new house
How do you change locks in a house you are going to move into?
There are two options here. Completely replace the locks in place, or have a professional repin the locks to a random new key. Your best bet is to have a professional locksmith look at your situation and give you suggestions. You can also go to your local homecenter and walk the lock aisle. One recommendation is to get the locks so they all use the same key. A number of manufacturers today sell packs with deadbolt, key and knobs etc, set up with the same key. This is a convenience that does nothing to compromise your security.
A good locksmith can possibly pick your lock. This is a dying art however. The cheaper your locks the easier it would be. Most burglaries are not done this way however. Since most houses do not have deadbolts, they simply loid (spread the door from the jamb) or kick the door in. In many cases they find a vulnerable window away from the street and open it. Basement windows are vulnerable as they can easily be compromised.
As for making a key from outside, yes, a skilled locksmith can do what is called impressioning. This is using a blank key, rock it in the cylinder, looking for pin markings and cuttting a key. This is very labor intensive and involves someone quite familiar with locks, who has the correct key blanks and equipment.
I would strongly suggest that if you have concerns, have a professional locksmith inspect your premises for a security check and have him make recommendations for replacement locks and other devices to put you at ease. Look for a locksmith that is bonded, and has credentials as CML (Certified Master Locksmith).
Do not go with the fly by night types that work out of their cars. YOu want an established business that sends clean uniformed personnel who can provide you with the service you need. Most of your good locksmiths are members of organizations such as ALOA Associated Locksmiths of America, or a state organization. Some states require licensing.
Hope this helps.
Hope this helps.
