vinyl siding
Old 09-01-02, 03:11 PM
George-911
Question vinyl siding
I am putting vinyl siding on my new home,I have my starter strip level all the way around the house,I will have 4- outside corner posts that need put up,and from what I have read so far is to leave 1/4 of an inch at the top,and I need to know how much of the corner post, I Should leave below my starter strip?
Old 09-02-02, 05:26 AM
mrmojo's Avatar
about a 1/2 to 3/4
Old 09-05-02, 10:26 AM
thiggy's Avatar
One thing, however, is that you will have a problem with your first course of vinyl if your starter strip is under your corner pieces. You must install the corner trim first or at least cut back the starter strips so they will not be under the corners.
