brown gunk dripping on siding
Old 02-17-00, 12:35 PM
Guest
Post
New house thus new roof. Have noticed that the roof shingles are lifting around the edges of the house and that brown gunk has dripped all over the sides of the house. I am assuming that this is a result of the roof shingles lifting. There are no trees or other outdoor structures to interfere. Does anyone know what is causing the brown drippy tar looking stuff all over the siding?
Old 02-17-00, 09:44 PM
Guest
Smile
Contact your builder and/or the sub that did the roofing. Sounds like you may have a roofing warranty claim.
Old 03-10-00, 03:10 PM
Guest
Post
You already hit the nail on the head but I will tell you exactly what it is.
Before the roofers layed the shingles they put a 4" strip of wet cement "tar" probably too close to the edges of the roof under the shingles and on top of the felt. This strip of wet cement is there to keep water from getting into the roof but as you can see if it is exposed enough water will mix with it and stain any thing it runs over. The shingles were not nailed/installed properly or you would not have the problem. Some roofers run their starter course by turning a shingle upside down. By code this is wrong and would make all the nails holding any shingles 6 inches away from the lowest edge of the roof. By code the roofer should lay a starter course by laying the first shingle with the top of the eyes even with the edge of the eaves drip then cutting the excess shingle off, still nailing the shingle over the eyes but about 2" from edge. The sides should be what's double nailed. which means each shingle is nailed about 2" in from the edge all the way to the ridge.
This is only around the edges.
I've been a roofer for 17yrs. and truly dislike roofers who can't do their job...
I hope I could help... Keiser...
