Flat Porch Roof Leaks
Old 05-01-00, 03:10 PM
Guest
Thumbs up
I have an ongoing problem with my front porch flat roof. It has been re-shingled 4 times by professionals. I have had new gutters installed on it. And I have put "tar" in the "corner" between the top of the gutter and the bottom of the shingles. The rain still gets in and runs down the fascia board and even worse, water runs on top of the porch ceiling and then down the bricks. Water even runs down the chain to the porch light. CAN ANYONE HELP ME?
Old 05-01-00, 05:19 PM
Guest
Post
What the heck are you doing with shingles on a flat roof!!!?
First, they all come off.
Replace any rotted, or punky wood. Preferrably build up even a 2%(minimum) slope-away from the home.
Find a pro that is familier and can apply a torched-on modified bitumen polymer, with flashing, counter flashing, and scupper boxes. Good luck, did I forget anything guys?
Old 05-05-00, 07:19 PM
Guest
Post
Get rid of the flat roof and put a 5:12 on it.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
Old 05-05-00, 10:29 PM
Guest
Post
Shingles on a flat roof are a guaranteed leak. If you have no other choice than a flt roof in this area, due to headroom considerations, then install a patio type roof in it's place -- either a 'flat pan' or an insulated roof panel cover.
