roof cementing
I am purchasing a house with a partial metal roof, as the inspector indicated the roof needs to be sealed with a roof cement and repaired in certain areas ( very small holes) how is this done
Plastic roofing cement can be applied with a flat stick, like a paint stir stick, to cover the small holes. There are different types and colors of metal roof coatings (get the kind with fibers in it), such as Mobil-Kote (sp?) and mop or paint it on. Be careful and don't let it drip down on your fascia boards or siding. If you live in a hot climate, you might want to go with an aluminum color. If heat reflection is not a big issue where you live, black is more standard. Whatever matches your other roofing and house best.Good Luck!
