Slope of roof
What is the minimum slope required for good drainage on a single slope roof?
Building 25'x 25'.
Building 25'x 25'.
What kind of roofing will you be using? The answer to THAT question will answer your question.
If you are using standard comp. roofing (3 tab or architectural), then 3/12 is the minimum. If the roof will metal, then you can go as flat as 1/2 in 12, assuming that this will meet the snow and wind loads of what and where you are building. Best check with your local bldg. dept. first.
