Possible roof leak
Old 05-20-03, 11:29 AM
m1ckvb
Question Possible roof leak
This past winter we had one heavy snow storm. It wasn't until a few weeks later, after it was long gone that I noticed dried moisture areas on the drywall around the ceiling fan vent in the bathroom. I have looked in the attic while it was raining and I see no possible leaks. I have yet to figure out how the ceiling got wet. Could this be the result of the snow melting down into the vent pipe? Any advise on how to prevent it from happening again?
Thank you!
Old 05-20-03, 02:36 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
The moisture stain was caused by warm, moist air condensation forming in the cold vent pipe in an unheated attic space, and running back down it.
The solution is to insulate the vent pipe in the unheated space. One way is by wrapping insulation batts around the pipe and holding them in place with duct tape. Don't crush the insulation or you'll defeat its purpose. Should help prevent the problem in the future.
Good Luck!
Mike
Old 05-22-03, 05:37 AM
m1ckvb
Lightbulb
Well the idea that the condensation within the vent pipe in the attic, although it is entirely possible it doesn't explain why it only happened once. If it was condensation caused by the cool air in the attic then wouldn't you agree that the condensation would occur whenever the fan was used during cold weather? This is not the case. Therefore I am back to my original question. After a heavy snow fall why did my ceiling get wet around the fan vent? Now could it be possibly that the vent opening was covered by snow and the fan blowing melted the snow and it dripped into the vent???
Old 05-22-03, 08:28 AM
E
Yep. It happened to me. The snow was so heavy that it did cover the vents. When it melted ... well you know the story.
Also had a problem with the sealing of the vent at the roof line .. cracked, hard, weatherbeaten tar. Did you check to make sure this is not a problem?
Old 05-22-03, 09:37 AM
m1ckvb
Thank you! Well I looked but the roof is only 3 years old and I doubt that it would be that worn out by now. I guess I will just have to keep an eye on it. Thanks again
