roof pitch
roof pitch
I'm installing some gingerbread trim. I know how to calculate roof pitch but the numbers mean nothing to me....is there a way to figure out the angles in degrees that I can use to cut the trim accurately? Or is up the ladder with the wood the easiest way?
thanks
John
thanks
John
The only way you are going to get your trim accurate is cut to fit.
Which means getting up there, and measuring each angle. Using the pitch angle method you will only be close, but you will not be accurate. I always measure each angle.
