need for flashing on chimney?
Old 05-18-04, 06:44 PM
docT
I am in the process of buying a house in New England. The inspector pointed out that there is no flashing between the chimney and the shingled roof. The chimney is along the end of the house (as opposed to coming through the middle of the roof). It is sealed with caulking. The house was built 4 years ago. Is flashing necessary? The inspector suggests that this can be maintained by sealing between the roof and chimney every couple of years. I would appreciate any advice on this matter.
DocT
Old 05-18-04, 08:51 PM
The Inspector is right. It should be flashed. However, if he feels that caulking every couple of years will be ok, then go with what he says.
Old 05-19-04, 04:46 AM
docT
So how big a job is this to do? I thought flashing had to be done while the chimney is being constructed. Thanks for any advice.
Old 05-19-04, 05:07 AM
Usually it is done when you roof your house. It came be done now by any compentent roofer. Good Luck
Old 05-19-04, 06:25 AM
Idealy, the flashing is installed into the mortar joints as the chimney is constructed. Surface mounted flashing is available to the roofer. Surface mounted flashings end up relying on a bead of sealant for the final seal at the top of the bar. Sometimes mortar joints can be hard to seal, as they are not struck flush and have to be filled w/sealant.
Jim
Old 05-19-04, 09:55 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You for sure want to flash the chimney. Just caulking wont and cant hold up for long. As the roof and the chimney move around a lot from each other. The so called metal step shingles go up under the roof shingles there now and the counter flashing goes over them and fastened to the flue. This way things can move around and not leak. Get a good roofer or sheet metal shop to look at it and do it right .
ED
