Sagging sheathing over decent shingles
I am buying a house in PA (near philadelphia) that was built with 3/8" sheathing on 16" centers. The sheathing is generally sagging a little all over but in one place it is very weak. It is a colonial style home with an upper and lower roof. The shingles are only about 8 years old. There are no current or previous apparent leaks.
Questions:
1. Can I tear off the shingles and put 1/2" sheathing on top of the existing sheathing? I would obviously do this to the whole roof not just the really bad place.
2. Would OSB be appropriate for this job?
3. Are there any things that I need to think about as a result of having increased the thickness of the roof surface? (flashing, drip edge, etc.)
Thanks in advance for your comments.
Questions:
Received 1 Upvote
1 Post
Like said call and check code for where you are.
If you do add on you could just add on a new fascia board over the old one and come up higher to match the new roof edge. Then the standard metal drip edge should work.
ED
ED
