Flat Roof Problem
Old 08-03-04, 08:55 AM
PRINGLE
Flat Roof Problem
I have a flat roof app. 55 foot by 30 foot that is on a building about 80 years old that leaks. What I like to do is, put a rubber roof over half inch ply or fiber board. What kind of comments is there on this problem.
Thank You,
Pringle
Old 08-03-04, 06:54 PM
ALL old roofing/insulation/decking that is wet must be removed and replaced. You will most likely need a infrared survey or at least a good moisture meter to find the wet stuff. Wood fibreboard is acceptable recover board for most EPDM Mfrs. Check w/you mfr to be sure. Is your existing roof smooth surfaced or ballasted?
Jim
