gutters on a porch
Old 09-17-04, 09:30 AM
knvt
gutters on a porch
Hi,
I live in Vermont and am about to hang vinyl gutters on my covered front porch. There is currently crown moulding on the fascia, which I will have to remove to make the fascia flat. When I do that the gutters will then sit too far back so I will have to add a 1x4 to the fascia boards to bring them out enough to hang the gutters to. My quesion is,
where should the gutter be positioned in respect to the drip edge ( or roofline) is the roofline to be centered in the gutter, or is it ok to have the front edge of the gutter out about 1 inch past the roofline.by the way it is a low slope roof 1/12 pitch, so not a lot of fast moving water.
thanks
Old 09-17-04, 02:29 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
First dont do the vinyl gutters. Use the steel are aluminum gutters for sure. The vinyl dont last. Now on that low of slope roof for sure have the drip edge just about 1" off the back of the gutter. If not the water will over shoot the gutter on you. Id put a 2X4 on it not the 1X4
ED
Old 09-17-04, 02:41 PM
Hellrazor's Avatar
Plastic gutters will not survive many winters in the NE. The weight of ice and snow will cause them to twist and buckle.
Old 09-19-04, 06:58 AM
JUSTININRI
Thumbs up Facia
If You Go With Alum Gutters You Can Get A Different Kind Of Hanger And Will Not Need To Touch The Facia This Hanger Holds The Gutter In The Right Place Call Agutter Co. And Have A Seemless Gutter Run Off At Yor House They Will Have All Accesories Neede Including The Hangers I Speak Of
