Black streaks on roof
Old 09-21-04, 06:45 AM
R.Randall
Question Black streaks on roof
I'am seeing black streakes on my roof? What is it and how can i get rid of it.
Old 09-21-04, 06:37 PM
This is from an old post......
The black streaks forming on your roof are most likely a form of fungus or algae. If so, it is not deteriorating your roof.
Why and where it forms is pretty much a mystery. It is an airborne disturbance that will pick a house and land on it. Once it lands, it spreads very rapidly and can turn your roof completely black. It almost always starts on the north face of most roofs... don't know why.
We DO know that fungus/algae doesn't like certain products in leads and other metals such as zinc and copper. You may notice that this fungus/algae will not grow under any turbins, lead pipes, or metal flashing on the roof. That is because the rain hits this and washes down the roof keeping the fungus/algae from growing.
The good news is that it CAN be cleaned off with a bleach/water solution. The more bleach the better, but watch for the runoff on your landscaping. Bleach and flowers do not mix well. The unofficial mix to use would be 1/3 bleach, 1/3 water, and 1/3 TSP (Tri Sodium Phosphate - common detergent).
There is a company named Chicago Metallic that makes a product called "Shingle Shield" that is made specifically to clean roofs. They also have a "zinc strip" that can be installed to keep the algae from returning once cleaned.
To find out more about fungus/algae, the Asphalt Roofing Manufacturers Association (ARMA) has technical bulletins on their website. You may want to check them out.
Good luck.
Old 09-23-04, 11:31 AM
R.Randall
Thanx for the reply ,I will let you know.
