Replacing turbine
Old 10-24-04, 01:39 PM
sjwarren
Replacing turbine
I have a wind turbine ventilator over our bedroom that is making a lot of noise. I looked at it today. There is a hole worn in the metal on the turbine ventilator where it overhangs the turbine base. I cannot find any particular spot that the ventilator is rubbing on. The turbine ventilator moves back and forth a lot but I don't know if this is normal. I found a place that sells replacement ventilators with an adaptable ring sized to fit any 12" turbine base.
Any ideas on what to do or if the replacement turbine ventilators work?
Susan
Old 10-25-04, 05:41 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Thumbs down
Down here now they are out a thing of the past wind blowed them off let rain in. ID go for a power vent fan on a tstat .The only way to go. Ridge vent are out also let rain in and some of them blew off
ED
