Trimming shingles at eaves?
Old 12-17-04, 10:25 AM
Is there an easy way to trim the shingles in a straight line where they overhang the eaves? Seems to me I recall that a plywood blade installed backwards in a circular saw works, but i'm not positive. Any help?
Old 12-17-04, 10:53 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Just a sharp box cutter Is all we use. The blade gums right up for me ,dont work.
ED
Old 12-17-04, 12:54 PM
Does that work from the top as well? i can't imagine trying to cut thru (at some places) 2 layers of shingles with a utility knife from the top side and getting it to look halfway decent...but, If you think it'll work, i'll try it!
thanks for the reply!
Old 12-30-04, 10:44 AM
pgtek's Avatar
hi
why noy used a chalk line to mark it and then used a hook bade to fit your utility knife and work your way down
cheers
pgtek
Old 12-31-04, 08:58 PM
H
Don't Always Trim
You don't always WANT to cut shingles that overlap at eaves.
At eaves located at the lowest point of a slope just above a gutter, you want the shingles to overlap by 2-3 inches to insure proper water runoff.
Where shingles meet eaves along a gable end, they should be cut flush to the drip edge.
