Keeping Downspouts Thawed
New Member
Maybe I'm wrong but would it help to have the downspouts and drain pipes kept thawed allow the gutters to drain water before they freeze.
Would disconnecting the down spouts from the gutters help? I know this could create ice patches below.
IF you don't mind an increased enegry bill...........
You can purchase a "gutter heat tape" or "heat cable", made for Exterior use.
It's available in various lengths. It comes with instructions.
It's relatively easy to install. It can plug into an outside outlet.
When choosing the length you need, allow for the fact that it will run through the inside of your gutter as well as zig-zagging in and out of your gutter up onto the roof itself.
And.........you can run one end of it through the downspout if so desired.
Roofing Materials Wholsalers MAY offer a wider selection of lengths than typical "BIG BOX" stores
