roof question
Old 02-08-05, 01:18 PM
roof question
I want to tie a new roof to an existing roof . Can I remove the fascia and soffit and tye into the existing rafters . This is going to be a sun or Florida type room over a patio with open wall that I will sreen in .
Old 02-09-05, 06:45 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
yes you can but you need a flashing that is insert between the old roof and the new one to preavent leaking.
cheers
[pg
Old 02-09-05, 06:46 AM
pgtek's Avatar
ops forgot
you better check with your county, you might need a permit and submit plan and have approval first
cheers
pg
Old 02-09-05, 10:08 AM
shinstr's Avatar
tie-in
Jimi,
If you are going to physically tie the structures together as you described,
you will need to remove the first three rows/courses of shingles so that your roofing membrane for the sun room can run up under the existing roofing, then replace the shingles you removed keeping the nails "high" in the lowest course. This will provide a seamless transition with no seperate flashings required. Less is more! The more you try to divide the roof areas...the more chance to create a problem.
Good Luck!
