Too cold for roofing!
Old 03-30-05, 09:24 AM
E
Is there a temperature below which a roof should not be installed? If above freezing ... OK? Should the temperature be above "X"? Should the roof be put on before vinyl siding?
Old 03-30-05, 12:54 PM
E
I go by the temp of the material. I've shingled in 30 degree temps, no problem because our sun warms the shingles themselves up to 50-60 degrees. There's always "ideal temps" I guess...like spring and fall. But in the real world us guys need to work, and folks need roofs installed in colder weather, so I use my head and will not shingle in temps that could damage them,but will install them in colder temps.
It is harder to properly flash a roof once the vinyl siding is installed.
Old 03-30-05, 07:39 PM
Cold Weather
We have installed shingles in all temps. Even 15 below. We just use a shingle heater to warm them before we nailed them down. Never have had a problem. Yes, roofing should be done before the sideing. Good Luck
