Chimney flashing leak
During yesterday's heavy rain, I used the opportunity to go up in my crawl-space attic and check for leaks. I found a very minor one where a small amount of water was coming in down the chimney. It appears it is coming in behind the step-flashing. What kind of sealant should I use up there to seal that up? I just purchased some "Gutter and Flashing" sealant for another job, would that work ok for this job?
hi
just get osmer cheap black roofing cement in a tube some are call black top other roofing cement.
Wear old close you might get some on you and wear disposal rubber glove.
This thing does make a mess on you
cheers
pg
cheers
pg
Received 1 Upvote
1 Post
While your up there besure and check on the cement cap on top of the chimney. Lots of time this is where water can get down in and run in the bricks to make it look like its the flashing.
ED
ED
