down spout drainage
Old 04-05-05, 09:21 AM
drnbean
down spout drainage
Immediately beside the outer wall of my house are 2 open, 2 1/2" diameter PVC pipes that stick out vertically a foot from the ground. One pipe is located to the rear corner of the house and the other pipe is on the opposite front corner of the house in the basement window well. My question for anyone is....can I run my gutter down spouts into these pipes since I assume they are drainage pipes meant for this purpose? What else could they be and how can I find out where they drain to?
Old 04-05-05, 04:32 PM
E
Sounds to me like they're drainage for your gutters. You might flood them with watrer from a hose to see if they're plugged...because I wonder why they're not already being used that way.
Old 04-14-05, 10:58 PM
sonnyv
Isn't a 2 1/2 inch pipe a little too small for a gutter drain? I wouldn't connect my down spout to it even if it was meant to be a drain. I don't think a down spout is any lest than 3 inches.
