Property Drainage
Old 04-06-05, 07:05 PM
F
Exclamation Property Drainage
I am considering buying a home that is on a relatively steep slope. Inspector says he cant see water damage in the basement, but sees runoff areas along the side of the house. There is also terracing in the yard I guess to slow drainage. Basement seems dry, but a small portion of it was recently redone. Front yard is angled the way it should be, but back angles straight to house. There is about 8 feet of flat ground between the hill and the incline.
Should I be concerned about this before buying? The rest of the house seems nice. Any suggestions for who I could hire to give it a good look?
Thanks,
Old 04-07-05, 06:09 AM
E
What about a Soil Engineer?
I work with a Home Inspector who's an actuall structural engineer. He looked at my house before I purchased and desribed the soil to me.
But I think there is such a thing as an actual Soil Engineer.
Old 04-07-05, 02:29 PM
shinstr's Avatar
Soils Engineering falls under a "Geotechnical Engineer"
Ground water in that situation is mainly delt with in two ways (not to say there arent others)
Either collected at the rear of the house by a buried drainage pipe "french drain" and simply diverted around the house (could explain the runoff on either side) look for a discharge pipe in the side or front yard.
Or routed to a sump in the basement to be pumped out to the storm sewer.
Good Luck!
Old 04-07-05, 08:34 PM
F
Thanks for the tip, I'll look into it!
Old 04-08-05, 05:14 AM
E
And to think I was orginally going to call them Dirt Doctors...
Old 04-08-05, 06:00 PM
Hellrazor's Avatar
Mud slingers...
