Removing ashphalt shingles
Old 04-15-05, 05:31 AM
O
I'm installing a skylight. Going to remove a 3' x 3' square of shingles, then cut hole in deck. I'd like to be able to reuse some of the shingles around the flashing.
Any tricks to getting the shingles up so that they are in decent shape and reusable?
Old 04-15-05, 06:02 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
Hi
Depending how old they are.
You need to loosen the tab and insert a wonder bar under it and pry up the nails.
you will loose some for sure but not all.
cheers
pg
Old 04-15-05, 11:59 AM
shinstr's Avatar
Water Displacement perfected on the 40th try....(WD-40)
