Water in gutter
I don't see why "they cannot seem to pitch it right". It's not uncommon to see small "jutouts" hold water because the gutters weren't pitched properly.
Not sure about your downspout thought....but downspouts can be attatched to amything I can think of. A small 1inch area of concrete sticking out wouldn't make much difference visually. But maybe I'm not understanding what you're saying on that.............
It would be suprising if this 18" portion of gutter was the lowest part of your gutter. Your installers should have tried to raise this area as high as possible, since the drops are on each end. It sounds to me like you may have a valley that is overshooting the gutter when it rains hard. Perhaps a deflector on this corner would help to prevent this from being a problem.
If you do need another downspout, remember that your downspout could go straight down and elbow onto the roof below or into another gutter, provided there is one.
It should surprise one when a small 18" 'jutout' holds water.
Have seen it many times myself though. I think it has something to do with the fact the "jutout" itself is lower due to the continuation of the pitch of the roof. Well...and maybe also that the gutter guy didn't give a cowpeye. Boy wouldn't that be rare...a construction service business which didn't care if their work worked or not!
