Storm Drains
Old 04-20-05, 04:28 AM
homerthefoamer's Avatar
Storm Drains
I am adding an addition on the rear of my home. It will be on a crawl space. The existing home does not have storm drains. When I add on I need to run drain tile around the foundation and run a storm drain out to the culvert at the street and tie in. Any Help describing this task would be appreciated.
Old 04-21-05, 06:19 AM
shinstr's Avatar
Is foundation drainage necessary for a pier and beam foundation?
Check with your local code body, normally any tie-in to city, county, municipal storm sewer needs to be performed by a licensed plumber.
Good Luck!
