Minimum Roof Pitch
Old 05-01-05, 03:49 AM
F
Minimum Roof Pitch
I am planning a shed dormer with a roof that will have about 3:12 pitch. What is the recommended minimum roof pitch for conventional 3-tap shingles?
Old 05-01-05, 05:02 AM
Hellrazor's Avatar
Check with the manufacturer of the shingles you plan to use.
Old 05-01-05, 05:31 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
For sure check with the manufacturer. But most go on down below A 3:12.
ED
Old 05-01-05, 06:51 AM
F
ED
What does "go on down below" mean...steeper or less steep?
Old 05-01-05, 07:04 AM
Ed Imeduc's Avatar
Wink
I have seen some go down to a 2 1/2 :12 a flater roof.
Old 05-01-05, 02:15 PM
Received 850 Upvotes on 746 Posts
I have a brother in law who used to be a roofer. I always heard him say that less than 3:12 voided the warrannty. Whether or not that is true I don't know, but you see mobile homes with shingles and 3:12 pitch. I would think any less would be inviting trouble.
my 2 cents probably worth less
Old 05-02-05, 11:42 AM
F
I contacted the shingle manufacturer and they said:
"The minimum pitch for all GAF shingles is 2:12. However, be sure to follow the low-slope application instructions which include a 19" overlap of the underlayments for slope that low."
By the way, with some framing help from DIY Forum I got the slope increased to nearly 3-1/2:12 so it's full speed ahead for this project.
Old 05-02-05, 12:01 PM
E
Even though you can lay the 3-tabs down to a 2/12, you're asking for trouble if you don't either cover the entire area with a membrane first, or at LEAST 2 layers of felt....with EXTRA-WIDE drip edge flashings.
Have replace many...many MANY shingled-covered low-pitched areas, complete with new wood decking because of water seepage.....due to extremely low pitch.
Old 05-09-05, 07:26 AM
Most manufacturers follow this general rule:
Anything 2:12 to 4:12 can use composition shingles, but MUST have either 2 layers of felt or a waterproofing membrane (ice & water shield).
I would STRONGLY suggest using the waterproofing membrane. The manufacturers may allow 2 layers of felt, but, like E. Dodge indicated, I personally think you're inviting a problem.....just my opinion.
Anything 4:12 and over can use standard underlayment under the composition shingles.
Good luck.
