Leaky basement due to FAST moving H2O
Old 06-06-05, 08:06 PM
P
Here's my issue:
We have water coming through our basement walls. The area is located directly under our front door. During a heavy downpour the water will run over the gutter and pour through the mosaic bricks that make up the entranceway.
This area is where the two roofs connect, the gutter seems fine and is not blocked. Is there someway to extend the gutter? I have come up with an idea to just concrete this area to make it impermeable to the water. Are there any better ways to address this situation?
Old 06-07-05, 05:21 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
install an extension to the drain pipe to move the water away from the house and slope the terrain also away from the house foundation should do it
Old 06-07-05, 08:08 AM
C
You say your gutters are not blocked, but what about the downspouts? After purchasing our home, I found one of my downspouts (near where a tree limb overhung the house) was clogged by leaves. I noticed when the gutters were overflowing that there was barely a trickle coming out of the downspout.
If your downspout is clear, you might consider replacing them with a larger size downspout that can handle a larger volume of water.
As mentioned before, definately divert the water coming out of the downspouts well away from the house.
Old 06-07-05, 08:12 AM
Ed Imeduc's Avatar
Wink
Run a water hose in the downspout up on the gutter full open and see if it drains??
ED
Old 06-07-05, 04:42 PM
P
Thanks for the input.
The gutters and the downspout are not blocked. It is only the water that comes off the 'valley' between the two roofs that overflows.
Here are some movies to illustrate the problem:
http://home.comcast.net/~dnashort/rain1.mpg
http://home.comcast.net/~dnashort/rain2.mpg
Dan
Old 06-14-05, 05:35 AM
pgtek's Avatar
Hi
I see your problem
you need to instal some kind of deviation from the valley to split the water running down the valley.
It's an easy fix
get a piece of aluminium the same color of your gutter let say 12 inches long by 6 inches wide
bent about 3/4 inches wide the aluminium all along the 12 in part like and L shape
them place it on the edge of the gutter and secure the L part to the gutter edge
align it facing the valley
Old 06-14-05, 06:56 AM
shinstr's Avatar
Keep in mind...concrete is not impermeable.
And make sure there is a good bead of sealant where the front porch slab/tile butt up against the foundation, top and sides.
