Cricket Fabrication
Old 07-14-05, 03:30 AM
coach8
Cricket Fabrication
Hello, we have a rancher style home, and 2/3 of the house has an attic with a typical roof, the other 1/3 had a flat roof that we have taken off and put up an A frame. The new A frame meets the existing to create a V, we need to create a cricket there to divert rain and snow off the roof. Does anyone have a nice drawing of how a cricket should be fabricated? It spans approx. 5 feet.
Thanks, John.
Old 07-14-05, 07:05 AM
shinstr's Avatar
Its hard to say without seeing the design of the roof.
Post a photo somewhere and put a link to it here.
Old 07-16-05, 05:32 AM
coach8
Roof Cricket
Shinstr, here is the link, thanks.
http://www.thetileguys1.com/roof.html
Old 07-16-05, 06:51 PM
XSleeper's Avatar
Received 1,963 Upvotes on 1,760 Posts
It looks like the roof on the left is right at 12' long, so it looks to me like if you found the middle of the left roof, you could level a ridge board from the middle (6' from the bottom of the current valley, or at the peak- whichever comes first) of the left roof to wherever it ends on the right roof. You'd have to square it by measuring 3:4:5 off a straight line on the left ridge. From each end of that ridge, you'd snap a line to the bottom of each valley (you'll have 2 valleys on each side of the ridge) That line will represent the ends of your valley jack rafters.
Is this what you'd do shinstr?
Old 07-24-05, 02:42 AM
coach8
Any chance of an illustration of your reply?
Old 07-24-05, 02:36 PM
XSleeper's Avatar
Ok, here's just a simple illustration to give you the idea. The roof would look essentially the same from the other side- there would also be 2 valleys on the opposite side of the ridge. That's why the ridge should be located in the center of the left roof- so that the valleys on each side will match.
http://pg.photos.yahoo.com/ph/thexsleeper/detail?.dir=af9d&.dnm=1e49.jpg&.src=ph
