Roof / shingle mold
Old 09-09-05, 10:18 AM
Roof / shingle mold
What's the best way to remove mold from shingles? Should a power washer be used? Do the zinc strips really work for preventing future stains? Do they look bad - like I'm envisioning they may?
Thanks.
Old 09-09-05, 12:09 PM
shinstr's Avatar
Don't use a pressure washer...This will do more damage than good.
Check out the "Maryland" post for information on removing mold.
Chlorine bleach is ok in VERY diluted quantities. Or used the OXY-Clean or similar you always see advertised.
The zink strip will be barely noticeable.
You tuck the metal under the ridge cap. Remove the ridge cap and lay the strips with 2-3 inches of the zink to be left exposed once the ridge is re-applied. The nails that hold the ridge cap on also secure the strip.
Good Luck!
Old 09-23-05, 09:32 PM
kmn
There are shingle wash concentrates available out there. They work pretty good on mold but do not prevent it from coming back. Use the zinc strips and that should help cure the problem.
