flat roof repair
Old 10-29-05, 09:49 AM
judehung
flat roof repair
We have a small flat roof over a sun porch and it needs to be repaired and we've had several different contractors out to look at it. one contractor recommended using the newer rubberized material - SBS modified mop down and another said he would use the more traditional roofing that's applied with torches, I did hear somewhere that there is a danger that can go on fire after it is applied. any suggestions as to which would be better?
Old 10-29-05, 04:32 PM
L
the newer rubberized material would be best . but as far as the tar goes unless you plan on haveing a fire on it dont worry
