How to seal gutter seems?
Old 12-03-05, 06:41 PM
rward
Hello all,
I have "seemless" aluminum gutters that have developed leaks at the corners (i.e. seems). I think it's from water that freezes and pushes the seems open. Anyway, I have tried silicon gutter repair, but some of the corners are already leaking this winter. Any suggestions? Thanks.
RW
Old 12-04-05, 06:53 AM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
I use this product:
http://www.doityourself.com/store/6696132.htm
It's clear like silicone, and it's great for brushing (or pouring... they make a similar product that is self-levelling) into gutters to seal up those leaks. I like to fill up those gutter corners so that there isn't a "dip" in the corner that will hold water, and then coat the seams up the sides as well, making sure you're getting the sealant into the joint, not just painting the surface.
