Leaking Crawlspace
Old 01-18-06, 02:53 PM
Leaking Crawlspace
Hello,
I was planning on waterproofing my crawlspace (From the outside). The house is on a grade which slopes from North --> South. Every time it rains water collects on the south side of the crawlspace against the foundation wall. I was planning on doing the following:
a) Dig a trench around the perimeter (Probably use a Ditch Witch - I believe the the footings are no more than 5 feet deep. Is it safe to use a Ditch Witch close to the foundation?) upto the footings.
b) Lay perforated pipes along the foundation covered with a sleeve.
c) Stucco the wall, then use Bituthene Waterproofing membrane. Before putting the gravel into the trench, put a form board against the wall and then fill te trench with gravel.
d) Backfill it with Mud.
Do I have to use landscapers fabric before I throw mud on top of the gravel. Any ideas/comments appreciated. Thanks.
Sshel
Old 01-18-06, 03:14 PM
Received 1 Upvote on 1 Post
Leaking Crawlspace
Definitely put landscape fabric around the rock or use a well graded sand to prevent the fines from washing into the drainage pipe.
Run the perforated drain pipe to a sump out out to daylight where the water can drain away.
Do not cover the rock with mud. Use a good backfill.
Before you do any of the above, make sure you have done the easiest, most positive and cheapest thing - have gutter extensions that carry the water out beyond the "swimming pool" that was dug by the contractor before he put a foundation in it. Then, shape your drainage to prevent water from running toward the house. Letting water run up to a wall does not make sense.
Dick
