Green Roof
Old 02-21-06, 07:15 AM
Green Roof
I tried this in the architecture forum, but I think this might be a better match.
Does anyone know anything about "green roofs" where you plant a low ground cover in a lightweight growing medium? Helps with run off, heat gain, etc.
I want to build a small garage (20X20) with a green roof and need some info on design requirements, for the foundation, roof, walls, etc. (particulary the roof). I want to be able to build this with no interior walls or supports (i.e. I want the full open space inside the garage). While I am looking for design ideas, this is not something I want to design myself. I will get an engineer or architect, but I want to get some general ideas at this point.
Any comments would be appreciated, but I would respectfully request that you not respond unless you actually know something about these types of roofs.
Old 02-21-06, 12:23 PM
D
You may want to check out the following for research projects concerning green roofs:
http://www.greenroofplants.com/research_and_development.htm#Penn%20State%20University
Good luck.
Don
