Leaking Carport
Old 08-23-06, 08:52 PM
C
Leaking Carport
I have one of those garage buildings sided with corrugated aluminum panels. There's a carport attached which is covered with corrugated fiberglass panels. The guy who built this rig sealed the corrugated aluminum - corrugated fiberglass joint with roofing tar. Guess what happened....
Surprise, surprise. The structure supporting that joint is all rotten.
Here's my question: When I get the stuff repaired is there a better way to seal the huge gaps around those corrugations? A proper flashing job doesn't seem practical. There is a foam sealant material that comes in arisol cans. I wonder if that's suitable for this application.
Old 08-23-06, 10:18 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
If you mean to go across the corrugated roof Home depot and lowes Have a foam filler like that fits the corrugated you Can use under the flashing.
ED
Old 08-24-06, 02:10 AM
C
Here are some photos of the carport with the fiberglass panels removed.
http://pg.photos.yahoo.com/ph/efm01/album?.dir=cce3scd&.src=ph
The seal between the carport cover and the garage leaked and rotted the wooden support structure. You can see that flashing that joint is probably impractical. I'm looking for a better way to seal this joint than the roofing cement which failed.
