Aluminum Roof
Aluminum Roof
Hey, thanks for all the great advice you guys offer, I've been reading the stuff here for quite a while.
I've got an issue I was hoping someone would help with. I'm in the process of removing an old aluminum roof, but the edges run up under aluminum siding on 2 adjoining walls. Is it possible to remove the roof without taking off the siding? Or to somehow take off the siding without damaging it? Thanks in advance... Hopefully I can get this worked out before it rains on monday
Sure- get yourself an angle grinder and some thin 1/16" thick abrasive blades. Cut the roof where it is flashed under the siding. I imagine the problem will be how you are going to make it rain-proof after the roof is removed.
