I think he said "drip ledge."
I think it's time for a new roof (leaks today). I mentioned it to a handyman a few months ago as he was backing down the driveway. He shouted "Be sure to get a 'drip ledge' when you get a new roof." I think he said drip ledge but I'm not sure. Anyway I think it's something roofers install near where the shingles meet the facia board to prevent water from trickling down the walls. Sounds like a good idea to me.
Appreciate any info ...
Yes, it's called "drip edge". There are a couple different styles- some longer than others. Usually available in white, almond, brown, and galvanized. The drip edge is a metal flashing that sticks out about 1" past your fascia. Most roofers will use drip edge and then cut their shingles so that they stick out 1/2" - 1" past the drip edge so that the water will run off the end of the shingles too.
In my area, we also use what is known as gutter apron above the gutters. It has a longer downward bend than drip edge, and is better at keeping water from running behind your gutters along the eves.
