roof leaks at vent pipe
Hello. my roof leaks at the area where the white pvc pipe exits the roof. Is there anything I can use to stop the leak from the inside? I have a fear of hights and cannot climb the roof. Would an expanding foam work?
It's hard to say what can and what can't be done to fix this problem without being able to look at it but If the leak is coming from the boot itself ( The part that slides around the PVC) then it's possible you could seal this from the inside.
More likely then not you or a hired professional is going to have to go on the roof to fix this problem.
Good luck,
Steven
Good luck,
Steven
