Torch down roof leak on end
I had a torch down roof installed last year. It had rained a lot in the last few days and water got into the house. I took a lot and tt appears that there is a leak where the roof end meets the side of the house. The torch down roof does not overlap the side of the house and from my viewpoint it looks like there appears to be an area where for water can get in. How can I repair this.
Did You Try Single Butyl Caulking?? (511) Flat Roofs Are Hard To Keep Sealed Especially At The Seams Of Your Existing Roof. Ususally Some Caulking Can Help If You Have A Good Idea Of Exactly Where It Is Leaking. Let Me Know How It Goes, I Am Asst Mgr Of Construction For A Metal Roof Installation Co. Just Curious: Are You Under Warranty For The Installation? You Should Be. If You Have Pd The Company To Install Flat On Your Home, They Should Back Their Work One Hundred Percent! We Do.
