Roof Trusses
Can the roof trusses be extented on a ranch style house ? If yes, how ? I
live in Tennessee in the country. No snow in the winter. Please help.
Thank you
Joe/Lefty
Thank you
Joe/Lefty
I'm making my house wider by 3 feet. I'm putting a shower in and need the
extra room. I have no room to extent the house.This is my only option.
Thank you
Joe/Lefty
Thank you
Joe/Lefty
Trusses
The truss ends are setting on a load bearing wall.
How much of this wall will be removed?
Have you considered how you will support the trusses if this wall is removed?
Extending the trusses will reduce the roof pitch for that part of the roof.
If the wall can be left in place, then consider adding a gable end for the addition. It would be at right angles to the present roof. You would then have the orginal roof and the new roof forming a valley on each side of the new portion. Hope this makes sense. Good luck. Post back and hopefully the pros will jump in and help out on this.
You cannot extend trusses. The truss really ends on top of the bearing wall. The gable type of addition is probably the one to use. It would be the least expensive. There is one other type, but very expensive. We just did one for a house extension. it is definetly not a DIY project, and probably most contractors would not even know how to do this type. Go with the gable. Good Luck
