Rippled Shingles
Old 02-28-07, 05:20 PM
L
Rippled Shingles
Any idea why a few shingles on my roof have a rippled wavy look to them?
Thanks in advance.
Linda
Old 02-28-07, 05:34 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
If it's a newly replaced roof, it could be the felt paper underlayment... sometimes big ripples in the felt will show up after the roof is shingled. Sometimes they will lay down when it gets hot... sometimes they won't.
Old 02-28-07, 07:56 PM
L
Thanks for the reply.
The roof is approximately 15 years old.
I don't recall seeing this wavy look during the summer so it will be interesting to see what happens when it gets hot.
Old 02-28-07, 08:18 PM
XSleeper's Avatar
If the wavy part is 3' long, it's likely the felt. If it's 4 ft long, a sheet of plywood might have popped loose. Can you hop up in the attic and check it out from below? It would indeed be strange for a 15 yr old roof to develop a ripple.
If it is a DIP, then there is likely a leak- a soft spot in the roof that is sagging under its own weight.
