Re-roofing
Old 04-05-07, 09:51 AM
C
Re-roofing
Which would be better?
I have corrogated roofing over 6" beams. I love the aged look and if possible would like to re-use the roofing. I would like more insulation - (walls are great, plastered adobe firred out on inside - at least 12" thick). Any ideas which woud be more economical? Adding something (rolled insulation? foam? ??) over the existing roof as-is and buy new corragated panels - how would I attach them? (and... I love the look the aged ones have) Remove corragation and fastening new 6" beams on top of the old, then add more insulation? A guess would be there's 1500 sq ft of roof when also accounting for the overhangs and pitch. Any guess on material costs?
Sorry if my questions are naieve - getting divorced and need to do, and learn to do, things on my own.
Thanks,
Cactus Wren
Old 04-05-07, 03:20 PM
W
Received 63 Upvotes on 55 Posts
Roof Insulation
The easiest would be to add insulation and vapor barrier between the rafters on the underside and enclose with beadboard, tongue-&-groove boards, or drywall. But then your beams will be hidden.
If metal is removed, then you can add 4-inch thick foam blocks between the sheathing and metal and secure the metal with long screws made for this purpose. Just a couple of ideas. I am sure the pros will have other suggestions. Good luck with your project.
