Water Proofing a Fiberglass Entry door
Old 07-30-07, 05:20 AM
N
Hi
I am planning to replace my entry door with a new fiberglass door - paintable type. I have heard that I should use Thompson seal to seal the edges. My question is when do I aply it? after applying the primer and paint? or before?
Thanks
Neil
Old 07-31-07, 12:55 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
I've never heard of "sealing" fiberglass.
I've fabricated hundreds of aircraft parts out of fiberglass and we just applied the primer and paint and it was done.
Doors maybe different....
Old 07-31-07, 01:15 PM
Received 840 Upvotes on 737 Posts
I'm not real familiar with fiberglass doors but with metal doors some have metal on all 6 sides while other brands may have exposed wood on the styles and tops and bottoms.
If the edges aren't factory sealed you should seal them. Use the same coating that you use to paint/poly the door. I'd skip the water seal - paint or poly will protect better.
Old 07-31-07, 08:55 PM
N
Sealing edges on a fiber glass door
Marksr
Thanks for the tip. What is a poly and where can I find it? also whed does one apply it?
Thanks
Old 08-01-07, 05:06 AM
W
Received 63 Upvotes on 55 Posts
Door
"Poly" is polyurethane, a clear, protective finish. You will find it at paint stores or in the paint department at your local big box store.
