problem w/gutters draining into ground
Old 10-12-07, 04:14 PM
D
my gutters go into a plastic pipe that goes into the ground and backs up .i want to redo this line with pvc underground and out.is this ok or should i use the flex pipe
Old 10-13-07, 06:50 AM
Received 824 Upvotes on 722 Posts
You can use either. The 4" flexable drain tile is probably easier to use - no problem making slight bends. PVC is less likely to collaspe later but you may have a time making bends that don't conform to the available fittings
Old 10-13-07, 09:00 PM
H
If you use flex pipe, make sure you put a sleeve over it so it won't block again.
To be real serious, dig a trench about 12" and appropriately deep with your flow add a few inches of lime rock at the bottom, put the pipe in (sleeved) and add lime rock up do approx 6" from the top. It'll last forever!
