Small Leak in roof
Old 10-25-07, 08:03 AM
Small Leak in roof
I have a small leak in my roof, which is ten years old.
When I go into the attic the drip is coming from a "plywood clip" the joins two pieces of plywood. That may not be the source but that is where the drip is coming from.
I am having trouble locating the leak on the top. Any suggestions on what to do locate and isolate where it is coming from.
Thanks, Tom
Old 10-25-07, 04:46 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Water can travel downhill quite a ways before coming in, so locate where the water is dripping... then go outside and find that spot. The leak will likely be occurring anywhere from 1 to 20 feet above where the drip is.
Things to suspect are ridge vents, can vents, vent pipe boots, chimneys, valleys, etc.
