Gutter slope
Gutter slope
Putting gutters on new garage,about 25 feet ,Does anyone know how much should I slope gutter from front to back and which is better plastic or alummunim? thxs
Frankly I like aluminum. and I would try to find a continous piece so that you can avoid seams. It will cost you a little more but you'll more than make up for it when you go to install it. Hidden ( or conceiled) brackets will do a good job holding up the gutter. Wrap around straps will also do a good job. Try and stay away from spikes and furrels.
PS You wont be able to buy continous gutter at a big box, theey only sell 10 ft lengths.
You dont need a large fall you just need a fall sufficient to carry water down the gutter. 1" should be more than sufficient.
Agreed...1" should be good.
Accepted standard for residential gutter slope to drain is between 1/4 inch to 1/2 inch per 10'.
Keep in mind not to over-pitch the guttering either, as this can flood the downspout(s) and cause overflow of the gutter in heavy rains.
