A few Roof shething questions.
Old 11-15-07, 06:46 AM
markzrt1's Avatar
I'm building a 20'x20' garage in Minnesota. It has a 5/12 pitch. I plan on using 5/8" OSB for the sheathing. My question is how much do you overhang the sheathing on the rake edge if any? Does it overhang the 2x6 sub-fascia? What size nails are generally used to attach the sheathing?
Old 11-15-07, 08:03 AM
W
Received 63 Upvotes on 55 Posts
Sheathing
If high wind area, use adhesive and 10 d sinkers. Run flush with outside of sub-fascia along the rake and install drip edge. Slide fascia wrap up under drip edge. Good luck with your project.
