PVC roofing?? how to
Old 11-15-07, 03:38 PM
seal them?
Need to install some PVC sheets (flat roof).
12 feet won;t be long enough. I need to add another 2 feet.
How do I seal that? make sure the water does not go through.
Any sealant you would recommend?
The sheets will be clear color
Thank you
Old 11-16-07, 05:01 PM
tinner666's Avatar
Thumbs up
No sealant. You weld the seams with a Leicester or Sieverts Hot-Air Welder. I think they're about $500. each.
Old 11-17-07, 05:24 AM
shinstr's Avatar
Check with a local supplier for "solvent weldable" products
Or better yet, switch to EPDM.
PVC membranes are not very forgiving when it comes to seaming.
