reroofing with a rubber roof in winter
Old 01-25-08, 12:53 PM
Z
hi all
i have a flat roof with roll asfalt roofing material
i had some leaks in different areas i guess it's time to reroof
i want to reroof with EPDM rubber roofing with underlayment
few questions here
could i apply this roofing material over the old roofing materal?
could i do it now or i need to wait till summer?
a) there is some snow on the roof right now and i'll clean it up
but my consern is moisture will be traped under the new roofing material as i said the roof had some leaks so there still might be some moisture traped there
b) how flexible is this material in cold weather in 25 F
thanks
Old 03-10-08, 01:46 PM
Wait For Warmer Weather
Rubber Roofing Is All About The Steps One Must Take To Get It Done Right The Addhesive Or Glue To Most People Will Freeze In The Cold Weather Making Alot Of Problems When Trying To Put Down The Rubber If It Dont Stick Your Screwed Wrinkles Bubbles Just A Mess To Deal With If You Want It To Look Good Read Into It Before You Do It
